Lynn D. Brown
Hey Guys,
I've got 2 Aux Coolers - both of them the serpentine copper tube type, and 2 applications for them. I definitely need a Trans cooler for my 3200 RPM 9/11 TC, and I thought I might put in an Aux IC cooler at the bottom.
Both of the Coolers are about 7½-8" high, and one of them is much wider than the other - 17" vs 9". I was thinking to use the bigger one as the Aux Trans cooler in front of the AC Condenser in the front. Altho' it is hard to get in there behind the front center support. I will probably need to loosen the AC Condenser so that I can slip it in there, and it will be tight against the condenser. Let's see now, does the stock radiator Trans Cooler go in the top or the bottom ?
I thought I would use the small one behind the lower IC, as Rick Nolan said he was able to fit his in there. I bought 2 small fans on a GP a couple of years ago that I can use there also. Has anyone installed these fans in there ? Where did U mount them ?
