here's a cooling trick i learned from an old schooler-
take washers and place them in between the hood hinge/hood bolts. use enough washers to raise the hood about 1/4" in the back. poor man's cowl hood. i tried it and it works. when the truck is idling you can put your hand above the gap...so much heat comes out you gotta pull your hand away.
