Owned
Took car in for smog and heard an miss. Checked dis and literally dis and spark plug cables in bad shape. After changing the dis and cables cables got two codes. First code 12 second cold 42. Stock coil, new distribitor. Map 3 mildly stocked RPM style. I'm assuming code 42 might have something to do with the ICM. The dis I used was an richporter they claim new. What do u guys think, should I swap the ICM from the old dist to see if code 42 goes away knowing the new dis has an problem or is code 42 total related to something else? The truck turned on and sounded good but nok test drive yet. What do u guys recommend?
