Couple ECM DAQ's
These 2, especially the second, have bothered me for a while. Thought I swallow my pride and throw 'em out there. :roll:
1) I read that "all" ECM's run in open loop at full throttle. Mine doesn't, or at least it doesn't show up in DM as open loop. Is that an issue? Truck seems to run fine at FT so just curious I guess.
2) This Q is more weird.:rotf: When we set timing we disconnect the brown wire and set it to -0-. At this point the dist is mechanically "locked" there. IOW, as I understand, there is not signal to the coil until the dist (the reluctor wheel) reaches that point. Since there is no mechanical advance mechanism how does the ECM advance the spark when the dist (reluctor) is still physically locked at that -0- point? I know it happens, just curious how it happens.
Thanks
Re: Couple ECM DAQ's
The Open Loop Q came from the recent PLX thread.
Being an old-school mechanical type guy and not being a programmer, IE code 59 for example, the advance question has always bugged me. What magic is occuring where the ECM can fire the coil "ahead" of when the reluctor triggers.
Thanks Dave, If that's what's happening it makes perfect sense. Good guess if nothing else. :tup:
Wanna take a stab at the Open Loop question?
