cracked left manifold... helppppp
supastar2
ok finially found my exhuast leak.. its the left turbo side and the center port has a crack on each side.. so this isnt worth fixing!!! helllpppppp i neeed a left side asap!!!!!! Thanx
Quickstop [UK]
Combating adversyty.
Re: cracked left manifold... helppppp
Have you thought of getting it welded? That's an odd place for it to let go.
yar
If it is the turbo side it is the right side, when you are sitting in the truck is how you get left and right.
Not standing in front and looking at the truck.
Hope this helps.
Ray
MadMike
Parts are typically called out left (driverside) and right (passenger) for the exception of what is related to the engine. Engine left and right is determined facing the front of the engine. eg. SBC Number 1 cylinder is right front.
The person called it out so either way we know what they are talking about....
IMHO I would take of the manifold and have it repaired. The manifolds are rare and should not be discarded. Take it to a reputable weld shop and they can determine the best way to fix it. My understanding is it that it will be TIGed or brazed with a Hi Nickle alloy. Oh and the ends of the crack drilled out to stop the crack from spreading.
Don't let anyone braze it, braze equals brass and will make future repairs almost impossible.
The hi nickle rod is correct. The procedure for welding cast iron is call the 3 ppp's. Pre Heat, (weld) Post Heat, and Pray.
I've repaired a few syty manifolds doing the above and it works. Never had one recrack that I know of.
s106banger
save em!
if you end up replacing it let me know! might be interested in your old one.
Syclone22
Hi There i have a complete set for sale but can
split it if your interested !!!!
supastar2
Yes i everything I seen forsale on ebay and googling says right side which is the driver side n common to all 4.3 v6s.. figures I need the harder side passenger or left side for the turbo.. I would feel better to ge a replacement n install it. N then have mine fixed for a spare... I wanna be able to remove and replace right away or I would even trade mine plus mone for another.... I just can't take the sound.. its deff cracked on the left and right side of the center port... I started it today n while it warmed up I felt the air coming out of it.. I emailed sportmachines with no responce yet.. :( I'm located in central new jersey n don't know of a shop id trust to have the skill to repair it.. id like to have it done right... do I need any gaskets for the manifold swap? Like against the head or where turbo is bolted in? its drivin me insannnneeeee... lol.. any help findin a good left or pair if I have to is appericated...
powercat6
You can't trust Ebay or a lot of other internet sources; the driver side is definitely SyTy specific just like the crossover and passenger side exhaust manifold.
