cracked pass exhaust mani
dpw41285
Spoolin'
this last week i could smell exhaust when i first fired it up, never thought anything about it. did my plug change this weekend (which is no big deal) and pulled the plug on the passenger side closest to the timing cover and noticed it was covered int exhaust gas. Thought for sure it was just a gasket leak untill i noticed the 1.5in crack right in the front of the manifold. Also that plug was a solid white color, obviously this could be another reason for some rough idling and power loss plus turbo lag since all of this is before the turbo and o2 sensor. So anyway what do i do now? Can cast iron be migged back to gether, or do i need a whole new manifold?
Brassmonkey
Cruzin' Mel Man
Re: cracked pass exhaust mani
Nickel stick weld is your best bet, but it is not easy. I had it done on mind and the weld has lasted a long time. There are several things to consider when doing/having the weld done. Do a search on here and you will find a thread.
TYTILIDIE
METH HEAD
I took mine to a local guy and he had it done in a few hours. Did a damn good job too. Cost me about $45.
TYTILIDIE
METH HEAD
did he nickel stick weld or standard mig weld?
Nickel. He also annealed it so that it would fit right on the head again. Mine was warped pretty bad. One other thing he told me was that one of the most important parts of the job was to ding it up with a ball ping hammer afterward. I don't know if he told me that just so I would think he was amazing but it worked and I haven't had any problems with it.
FWIW, I mig welded mine and 15 minutes later went over to look at it and the weld had cracked. It was a very nice looking weld too:(
critical
meltdown
maybe a cylinder head repair shop could fix them too. they have ovens that heat the entire casting for the weld repair.
welds expand in a cold casting, and unfortunately shrinks twice as much that pulls the weld apart.
Osmosis
I had my passenger side manifold welded becasue I had a few cracks that were leaking. Make sure you don't just weld the cracks with any old welder, such as a mig welder. Cast iron has to be welded a specific way or the weld will not work. I took my exhaust manifold to a machine shop. It ran me 75 bucks and my Ty has not leaked since:tup:
dpw41285
Spoolin'
i guess i shouldnt really put words in there mouth, i assume they will braze it.... but the guy said yes we can fix it and no it cant be mig welded
dpw41285
Spoolin'
so heres the update, the exhaust shop couldnt fix the crack it ended up cracking all the way around. I practiced mig on bbc cracked manifold yeah even on the lowest feed and amp settings your just about burning holes with out tacking and then bouncing around tacking agian untilll you get some wire in threre. it looked horrible but i am very confidnet it wont leak.... i still will be sending mine out. i cant find anyone in this tow that does cast repair.
I have done them, but if you have had others put weld in it its toast
Cast takes some prep work, the right rod, and post heating to cool it very slow. I use a tig process which is very controllable.
may? LOL
do you have a picture? I have another one thats cracked maybe could exchange it for you if in similar crack condition
dpw41285
Spoolin'
the crack is hairline. if you look straight at the manifold it is cracked all the way around the top and around, its under neath the turbo. sides are cracked the bottom is still intact. the leak is only in 25% of the crack which is at the very top. the hairline is 75% of the manifold though the bottom is still solid and the top is only leaking. gosh i hope that made since. i can send you a pic of my cell whats the email
