crankshaft vs oil pan
#2875
built, not bought
so i have my new engine running pretty well now except for a little vacuum issue and:
now it's time to pull off the oil pan and do some body work. as far as i can tell as it sits all counterweights above the flat part of the oil pan are hitting that flat part. has anybody else experienced this? the crank is a standard 10-10 4.3 cast crank that i picked up from the machine shop. the oil pan was pulled from an 89 sonoma 4wd. i am using a thick-ass gasket too. what is going on here?
#2875
built, not bought
Re: crankshaft vs oil pan
nope, i have never read anything in this forum about clearancing for these rods and i still can't find anything on it. hmm.
ghettosled
SYTY SUPERSTORE
You'll see two deep scratch marks when you pull the pan.. dent in with a hammer, and clearance without the gasket.. then once you add the gasket, you'll be even better.
#2875
built, not bought
thanks, i feel like an idiot. can you remove the pan without pulling the motor?
canadian
sy in progress
you can. there's a section in the chiltons manual about how to do it as well. from what i remember you have to mess with the front diff to get enough clearance to get the pan out (possibly remove the front diff).
