Cruise Control Switch
Slyclone
Well-known member
I was working on my typhoon under the dash when I first brought the truck home. I hit something attached to the brake pedal. It was a plastic switch thing. My head banged right into it and it snapped. I think DaveP mentioned to me it was something to do with cruise... but I cant remember to tell you the truth.
The transmission I kept thinking was slipping or my rear wheels were breaking loose. One or the other. I got around to checking fluid and I was a pint low... topped off trans fluid.
I am just wondering where all my trans fluid could be going? Is there VAC some where its getting pulled out of into? I checked fluid today, nothing came up on the stick. I got qt of trans fluid and put it in, rode around block and checked and was still low.
I recall one time I pulled a VAC ball out of a truck in the yard.. I ended up snapping the little nub to put the hose on... I went through all the trouble to yank it and not really check it out. I remember when I got home and looked closer at it It was actually FULL of TRANS FLUID. I pulled the vac ball from a 94 ish blazer it was a smaller hood mounted one..
Would my Cruise control switch being activated ( to the far left) and the broken part cause a vac loss and fill my ball up with fluid? How is it even possible in the first place to fill the vac ball with trans fluid?
I am loosing my fluid. I dont know if it was just me but I ended up clicking the cruise switch to the middle and it seem like it shift better. Like it was engaged, Maybe I am just loosing my mind? HA Some times I am real good at over analyzing thing. This could be a prime example
Static
Re: Cruise Control Switch
The 700r4 trans have no vac lines to them. possible that you were lower than you thought on trans fluid. keep topping it off.
gstacky
The cruise switch will have nothing to do with the trans issues. There is a hose that attached to the switch that when pressed basically blows air to the cruise unit, but that won't leak on you. Like mentioned, the 700R4 has no vac line, I don't know how that vac ball would have got trans fluid, other than people do stupid things sometimes. Are you checking the trans fluid with the truck running and at operating temperature? That is a must, it must be hot when checking the level, and they take a lot of fluid.
