I jut got my hands on a set of Brembo's from a 2005 CTS V. Which bracket kit should I go with for the front and also for the rear? Does any one have the brackets available?
please note, these do not allow for parking brake hookup. These will only mount the calipers and rotors to the rear axle. When time allows, i'll work on a parking brake setup for these calipers.
I don't know, there's no label on them. Renz, do you know what kind these are? I'm putting 19"x12" in the rears, and 19"x9" in the fronts. New z06 wheels
Topbrakes? they were the cheapest rotors i could find that were drilled, slotted, and zinc coated. Since he's doing 2 sets of these on 2 trucks, we wanted to get an entry level rotor to make sure everything would work. His main truck will likely get better rotors unless he loves these ones.
Note that you have to open up the hub opening of the rotor for these to fit our trucks. Not much - you can dremel it open if you have to. I had to do that to my test rotors since i can't swing 15.5" on my lathe.
