Only about 2k over budget :rotf: with more to come so wanted to share with the people who can appreciate it.
Splayed 4 bolt center mains
ARP main studs
Eagle rods
SRP pistons
JE Pro Seal rings
ARP head bolts
Block -0- decked to pistons
Vortec heads
.030 bore with torque plate, custom sized to pistons
Dura Bond cam bearings
Federal Mogal main & rod bearings
Custom multi-angle valve job
SI Valves Undercut and swirl polished
Stellite exhaust seats
Comp dual valve springs
Comp 412 cam
Comp pro magnum lifters
Balanced
SFI front damper
Stock Dist
Turbo oil filter from RPM
Melling 10552 oil pump
50# inj's
3" DP
Built trans
SFI flex plate
Specrite custom TC
Still Not decided yet: Turbo
To paraphrase: Little bit here, little bit there, pretty soon you're talking real money.
Assembly should be starting second week of Jan. Pics to follow
ARP main studs
Eagle rods
SRP pistons
JE Pro Seal rings
ARP head bolts
Vortec heads
Comp 412 cam
Balanced
SFI front damper
Stock Dist
50# inj's
3" DP
Built trans
SFI flex plate
Specrite custom TC
