OK, here's the direction I'm headed on my rebuild:
4 bolt splayed center mains
stock rods
.010/.010 internally balanced crank.
Still not decided on pistons but block will be .030 over and -0- decked
Comp 412 or 415 cam, or possible custom grind
L35 heads mild porting with a 5 angle valve job
No headers
20G turbo w/3" DP with some sort of cold air. (Bat moved to bed.)
$59 tune w/alky
There are 2 goals here; don't break the bank and run low to mid 12's consistently on 20lbs or less boost so motor runs for a long time. Whadaya think? Don't slam me to hard, :rotf: I can be convinced to change as none of these parts have been bought yet. (Figured I'd have the heads by now but haven't found any local.)
Time is, so far, is on my side as I don't need the truck to run until Jan or Feb.
stock rods
No headers
$59 tune w/alky
