Custom CNC pulley anyone?
0966Sy
Code what?
I've stumbled into what appears to be a pulley roadblock for my vaccum pump setup. Only way I have found to get accross without changing a whole ton of crap and going over budget would be perfect if I could only get this same damn Morroso pulley in 6 rib serpentine. The specs need to be the exact same, bolt pattern and 5". I could get away with 4-4.5" if i found one. I have looked all over the net and have not found anything I could make work. I have e-mailed Mike at RPM and havent heard back yet, tried to call but they must be out on vacation. Smog pump pulley's seem to be the only thing that is close.
http://www.summitracing.com/parts/MOR-64885/
Anyone know if it would be possible without being way over priced to have a custom 5" CNC pulley made?
Re: Custom CNC pulley anyone?
Anything is possible. Go to online metals.com and look up what a chunk of it costs first, keep in mind they will need enough material to chuck onto also 1" minimum.
Most shops are $40/hr +, guessing 4 hrs work with CNC. Might be just as fast to do it manual lathe with the right person on the controls for a one off.
I'd guess $200-$250 to have made at local machine shop. You would need to supply them with old pulley or dimensions.
MikeRenz
not stock
get a hold of john frey, bullysyclone. it's what he does and he'd definitely be able to make a pulley for you.
0966Sy
Code what?
Awesome guy's, thanks for the input. Once i get this pulley situation lined out i'll post more details on my vacuum pump setup. I'll PM John and wait for Mike to get back with me. I'd like to keep it in the SyTy community so all the R&R is done for anyone else interested. Truck must NOT have A/C though.
