Re: Custom Grind Cam
I just want to do a custom grind since its not much more than a off the shelf unit. Not to mention its designed for my setup and will have a better profile for turbo.
My setup will be:
Stock block, Vortec heads, Cryo crank, 4 bolt conversion, Eagle rods, Wiseco forged pistons, factory intake, PTE6266 (ball bearing), Factory manifolds, RPM downpipe with 3 inch exhaust, RPM A2A, 75lb injectors, Holley 58mm TB, 1.5 roller rockers. Will try to shoot for 550-650 HP range. Will be using Holley Dominator stand alone EFI.
