2500avalanche
Well-known member
I have a question that some experts might help me with. My Ty is running good, but I have ALWAYS got an exhaust smell in the cab. I know it is coming from where the DP connects to the test pipe or cat. The reason is the previous owner had someone weld a pipe (3" test pipe OVER the stock pipe OVER the DP to where it starts tthe first bend. I cut it off, but that resulted in a tiny bit of pipe being able to be used as the part for the test pipe to go over. I did use a wide exhaust clamp, and it helped some. I know there is no way to remove the DP with out cutting (and it looks like I will go that way so I can buy a new one from SM), but is this something an exhaust shop could fix and extend while on teh truck, and not look like crap? Any advice would be great!
