cv flange leak
1blkc4
Just replaced the cv axle flange seal on the passenger side with an ac delco seal well it still leaking wtf !!! What I noticed on the back side of the flange is dry it appears to be leaking where the cv bolts to the flange the bolts are wet there is no miles on this seal .
skolman91
Re: cv flange leak
Ive said similar in this thread recently http://www.syty.net/forums/showthread.php?t=104443
I might of worded some things wrong but what your describing agrees with what ive experienced imo. Cardone which manufactures the majority of the the cv axles is getting it wrong and the end caps arent getting expanded enough.. I returned the new cardone axles i bought from rockauto (which will only give you store credit after a yr btw or nothing) and went to napa and had them order me one axle (came in ****ed up and leaking like the rest) i finally got 2 that seem decent, i took a punch and expanded the cap seams then put rtv on them and hoping for better results
So long story short from my rant, their is a 6:1 order ratio in ordering brand new cv axles in which you might get one with no leaks.. good luck
Pic below is to clear up what leaks (look at the fluid pools at bottom of covers)..
Not to mention the fact that you might receive a cog style or round flange randomly ( both pictured) in any name brand box you receive which is ****ed up in its self imo..
1blkc4
Re: cv flange leak
Thanks I think that is the problem .The axles were changed before I bought the truck . What is the oem rounded or cogged ?
1blkc4
Re: cv flange leak
Mine is the cog style applied some rtv to where the joint bolts to the flange .
