Cylinder Volume in 749-$58
SABLT194
Hello SyTy's
I'm brand spanking new here. I've been on the thirdgen website and LT1 edit list for quite some time and have experience in tuning my LT1 and an $8D SD 730 ECM on a Big Block. My new project is putting a 749 on a 6:71 Blown 455 Olds. Sounds like a quite a task and the challange has been laid down that we'll never get it to run right. Sooooo, not being one to back down from a challange I orderd Tunercat $58 def file and started looking at some stock bins. Tunercat shows no place to change cylinder volume! Won't that be a critical number to have in the code to properly calculate BPW? I also downloaded Programmer to see if it was in there. It wasn't Here's the big Q, Is cylinder size in the code? or will I just have to back calculate the injector constant to make up the difference in volume on the Olds vs the 3.8?
BTW, neat BB- This boost stuff is gonna be interesting.
Thanks
Steve
Sy769
That's correct I don't know of a cylinder volume.
Our application of the 749 is a 4.3 not a 3.8
You need to find a copy of the P4 document. It's on one of the DIY EFI
pages It will explain how fuel scheduling is calculated. Matter of fact there is a lot of good reading in the DIY EFI archives.
Also not to be a ass or anything but to most this tuning section is for SyTy's only, not anything that you decide to put a 749 on.
Probably should be in Off Topic. But hey I am not a Mod :D I'll let them decide.
SABLT194
Oops, sorry about the 3.8/4.3 deal. I really do know better. I'll fudge the Constants to account for the different cylinder volume. Is that how GM does it for the Sunbird Turbos as well. Seems like an odd way of handling it since most of the older ECM's have cylinder size as an adjustable parameter.
Thanks for the info. I'm looking but haven't found the 749 hack on the GMECM site yet , any pointers are greatly appreciated.
:D
Thanks
Steve
BillC
Start your reading here:
ftp://ftp.diy-efi.org/pub/gmecm/manuals/1227749/Turbo_P4_Doc.pdf
This is the P4 document to which Sy769 is referring. It explains a lot of how things work inside the ECM.
It sounds like most of your changes will need to be with the injector constants and in the fueling tables (F30, F29 and F29E).
You should contact Nolan about getting the ECM modified to handle low-impedance injectors (look in the classifieds section). You might be able to size the injectors large enough to compensate for the increase in cylinder volume without needing to make radical changes in the chip.
The other thing you'll need to do is to make sure to set the chip to 8 cylinders instead of 6. :p
BTW, why are you wasting time with Tunercat when Promgrammer is obviously a far-superior product (and cheaper, too). (yeah, no bias here.... :wink: )
SABLT194
Thanks guys.
I think we'll be ok with high impedance injectors. The 455 is very mild and we won't be running very much boost. Actually we're starting with 30#'ers. I'm with you on the cylinder select set to "0" for 8 cylinders. I'll also be using a V8 Memcal out of a TPI 730. I'm most worried about tip in throttle response. We couldn't fit the injectors into the intake manifold (the blower was in the way) so there's an adaptor plate with the injectors between the throttle bodies and the blower. That's going to put some distance from the injectors to the valves. Sounds icky to me. Hmm, I'm probably gonna have to invest in a WB to figure this deal out.
Merry Xmas
Steve
SABLT194
It looks like the term in the hack is called BPC - Base pulse constant and that term is some combination of Injector size and cylinder volume. It's found at F28A but there is no additionl information infomation on how it's derived. I'm not too switft with assembly language soo I'll just have to wing it.
Steve
