Almost had a wrecked truck. Man in the cooler weather it shows no mercy to the tires.
I was passing a FedEx truck today hammered it at about 30 it cought second just right and swapped ends with me before I knew WTF happened. I went back to my office shacking so bad I could even sign my name.
well I still need to do some tunning. I need to work on the fueling in the 3000rpm range. I think timing is good just need to richen 3k up a little. I also think there is some more power to be made in the 4500-5000 range. Im only running 15lbs of boost though
Its probably slower than it was. I cant hook up at all. Damn thing goes nuts of the line and doesnt settle down until about 50mph
To date this is what the truck has
Stage 3 vortecs from Jerry McCoy
Cam, Lifters, Roller rockers
Ported intake
ATR headers
Dual core air to air
PTE stealth turbo
3" dp
3" cat back thru a 3" cat
10" 3k stall
blitz controller
Dual electric fans
Fuel pump and reg
ALL ON A STOCK BLOCK !!! :shocked!:
