what can a guy do to eliminate ignition problems? :evil:
it seems that if something is slightly not perfect with the ignition, that it wont work right.
if my plugs get a few hundred miles on them, i will get a slight high end sputter or ignition break-up. if i throw in new plugs, all is good again for a little while.
fwiw i have L35 heads and i use ngk ur6. i also have a new msd distributor and wires and coil. i even have a msd 6A box that i removed and problem still exists.
could the problem be that i need to run a hotter plug like a ur5? i never really boost more than 15psi or run race gas. could the colder plug(ur6) be getting fouled if it's not getting hot enough? does that even make sense? :-?
one other thing i thought of, could there be a voltage drop at the distributor when the rpms are increased, possibly due to insufficient factory wiring? would i be able to run another positive feed to the distributor to make sure i have no voltage drop?
somebody sell me a complete individual coil setup please.
