Dart vs Motown
TT350
Manufacturer
Looking into a aftermarket block duz any one know the pros and cons between the World products Motown block and the Dart?
The block I’m looking at is a standard deck height SBC 400 iron block.
100in6
100in6
Re: Dart vs Motown
i can give you a little info on dart. i built a stroker v8 and used their pro 1 heads. i had the motor built and assembled by wheel to wheel powertrain in warren michigan. i had considered using the dart block too and my buddies at wheel to wheel talked me out of it so i used a new gm performance block instead. heres what they told me. if i was gonna bulld a big inch small block the dart would be the way to go cause it's bigger and stronger. but it was a lot heavier and without wanting to go into the 427 and bigger inch area i didn't need it.
now if you're asking me me about the quality of darts stuff it's great. if money is no issue for you then go for it. i didn't and built an all forged bottom end with j&e pistons, comp cams mechanical roller, msd billet distributor and the dart heads and all the little stuffand am happy with it. it;s a torque monster.
if you decide you want the dart block call jory at wheel to wheel powertrain and tell them les reccomended you and see if they'll make you a good deal
any other info you want let me know
les
