data master pic launch 12 psi is anything look wrong
warsaw
Sy#1012
<a href="http://s779.photobucket.com/albums/yy77/warsaw223/?action=view&current=Capture.jpg" target="_blank"><img src="http://i779.photobucket.com/albums/yy77/warsaw223/Capture.jpg" border="0" alt="Photobucket"></a>
warsaw
Sy#1012
Re: data master pic launch 12 psi is anything look wrong
[/IMG]
warsaw
Sy#1012
sry dont know how to post a pic on here yet but there a link to photo bucket that shows the datamaster file
blazinmt
Just take that link you inserted and place it in the IMG box...the box you click on that looks like mountains and a moon on a yellow background
Goshinki
You don't want any Spark Retard.
When was the last time you did a tune up? (Spark plugs, wires, cap)
warsaw
Sy#1012
i just did a tune up all msd plugs ngk ur5
TYTILIDIE
METH HEAD
Doesn't look that bad for a stock truck however, it is running a little lean. Time to do the safety mods to your Ty. What are your plans for the truck?
BTW, I'm not sure if it makes a difference with new version of datamaster but you may want to de-select the code59 option as your Ty is not runnning it. So far I have not set out to find out what the difference is in the version that has the option but to be safe, might want to give it some thought.
warsaw
Sy#1012
what safety mods ? and as for my plan i want to get it in high 11 low 12 sec. but not to sure what i need to do any idea ? i was thinking stage 1 turbo from rpm./ 3 barmap/ 50lbs injectors/ fuelpump 255/ exhaust cat back not sure what kind/and alky/injection kit.dont know if that will get me where i want to be. if any has any info pls let me know
TYTILIDIE
METH HEAD
At our altitude I don't the RPM stage 1 will cut it for high 11's low 12's. JER and RY ran 11.8-12.2 on the T3/T4 set up. (if I'm not mistaken). Cheatham can run high 11's on the Stealth 70. A lot of it is going to break to how much work do you really want to do and how much money do you want to spend? I have seen a stock truck up here run 13.6 with just AFPR and 20g turbo. For up here that is not bad. I ran 13.2 with my 20g and alky. I think I could have done a little better but I could never get mine to go over 19psi. 25 I think would have gotten me there.
If I were you I would take it slow before you really say you want to run those times. It's hard enough to keep these things running stock, you are asking for many hours in the garage the faster you go with your Ty.
warsaw
Sy#1012
yea he let it go for cheap made me the happiest guy in colo. but the wife aint so happy and dont mind cause i got my typhoon hahaha
