mmp142965
say it like you spell it!
I have DM cable that looks like the one below...
After searching all day yesturday to figure out where the 2 leads plugged into the OBD1 port, It looked like the below ports A, and M made the most sense.
I figured red to M and red/black to A, I don't know if this is correct, this was an educated guess derived from a 3 hour search and some PM's.
Now, in the process of trying to get the datamaster software to connect to the truck I spent about $60 in a parallel to serial adapter and a serial to USB adapter, so in theory I could use either one. The datamaster version is the latest one from the tts website for our trucks.
No matter what COMI use it will not connect and depending on what I do I get these messsages from datamaster...
The ALDL adapter is working, but unknown data was detected. Something to that effect. This is with the USB adapter
The ALDL adapter is working, but no PCM was detected. This is with the serial/parallel adapter.
I obviously do not know the ins and outs of datamaster, but after reading the users manual I have a pretty good idea of how it is supposed to connect. I have used the moniter feature as well as the separate connection utility provided by tts. Nothing works. I tried PPITyphoons old post about building the cable, but all of the pics are down. Someone help me!!!!
