Datamaster boost bug
Buster
I know this question has came up before, so I thought I'd throw this up here. Its actually a baro bug I think. Datamaster was reading 22 psi last night when the map was only at 228 kpa, which doesn't make any sense at my altitude.
Anyhow, the Baro in the top corner read 57.2 which isn't even close, so I think this is why you'll get wacky boost conversion from time to time. Most of the time the baro will read 98.9 and then the boost to map conversion seems to be pretty close.
leroy
FWIW, I've seen the same thing on Diacom, so don't think it's a Datamaster problem. If I remember right the difference in the wacky Baro reading and the usual Baro reading can be applied to the boost reading to get you close. Everything still seems to run okay when this happens.
Jim
Falco
Mark,
I guess you removed the ECM fuse or one of the battery terminals before this run.
As far as I know it's a bug in our ECM's software/MAP readings. After a power cut it will show incorrect results in all pressure related fields, MAP, Bar, Vacuum, Boost... The first restart of the truck (ignition OFF-ON cycle) will correct this.
Later,
Buster
Falco said:
Mark,
Later,
Might be because of the romulator. I'll try cycling it, its really not a big deal as long as the map readings are correct. I think all the other pressure related fields are OK because I've been tuning off map and it seems to be right on. The boost conversion, based on the wacky baro reading makes sense, it actually reads 3 psi with the engine off.
