Datamaster Communication problems fixed!
ItsMyTy
Life is beter at 25 PSI
Just wanted to share this with everyone that's having datamaster errors and communication problems. It's been said many times, but check your
IGNITION!!!
I have a set of ATR plugwires on my Ty, about 10 months old, and the truck seemed to be running well. No misfires, running great at the track. Datamaster would have communication loss every 10 seconds or so, and reconnect after a second or so. Since I just made my own datamaster cable, I thought my cable was not as good as a TTS cable and I was gonna have to deal with the errors.
Fast forward to tonight... Truck dies going down the road, tach fluttering all over the place before I roll to a stop. Bad coil wire, won't even fire back up. Repaced the coil wire. Runs the same as before it died... but now, no communication errors at all in datamaster!!! Just because you have new wires doesn't mean they aren't bad... Lesson learned (and i'm keeping a spare coil wire in the console just in case...)
though this might help somebody
Tooky
Serious about performance
Thank you, highly interesting, I have dealt with Datamaster communication disconnects when helping other SyTy owners and I will definitely file this in my mental library.
Sy769
Resistance is not everything.
I have seen coil wires (all the wires actually) leak voltage everywhere. You can imagine the chaos this creates for computers.
myclone
Im glad someone else mentioned this as I doubt anyone would believe me.. All I can say is that in my line of work I see "leaky" cabling/wiring cause all kinds of issues no matter if they ohm good or not.
My point? Just cause a plug wire or set of plug wires ohm "good" does not mean they arent leaking HV like crazy. An ohm meter will not tell you if the insulation properties are any good as HV doesnt play by the rules we normally apply to lower voltages (~480v and below).
