Datamaster Data Error
Maxtor
I have heard this come up before, but never heard a resolution.
When I hook Datamaster up to 1713, it works great and never get data errors.
However, any time I hook it up to 959 I get multiple data errors and usually lose communication during a WOT run. 959 is 100% stockwith the stock ECM and chip. I've tried the obvious, cleaning the ALDL connections and ensuring everything is making good contact - no change. The truck runs great, no obvious problems. From the bits and pieces of runs I can see the data shows nothing wrong and pulls a 13.4 1/4 on G-Tech.
Any ideas? Even though it's stock, I would like to record an entire WOT run instead of bits and pieces.
Thanks.
myclone
Have you tried changing the data sync speed? Ive ran my DM on 4 diff trucks and the one closest to stock required changing the sync speed. The other 3 have some version of the ultimate and dont require any changes.
HTH
Sy769
I have this same situation. Under WOT I get the Data Err flag on quite a few records. I hooked up the MSD 6A as an experiment and it is much worse. I get a data error every few records even at idle. The only explanation I have found is that noise in the data stream can cause it which makes sense considering the noise that the MSD puts out. I have added extra grounds to the ecm and cleaned the engine to body grounds. Also stock chip and my hyperjunk chip make no difference.
Before my tune up I didn't have this problem. I did Conrad cap,rotor, Taylor wires and NGK UR6 plugs just before the Nats. I have already found one bad wire that was causing the tach to jump around,misfires etc. The other wires all tested about the same resistance as someone else had posted.
So has anyone else had the Taylors cause any extra noise? :-?
Any other ideas on finding the cause of the errors? :-?
BTW doesn't matter what the record rate is set on. Works perfectly except at sustained WOT. Voltage to the cig lighter plug is at about 13.5 at WOT
I can also send the file if it helps.
Thanks
myclone
FWIW..
The ultimate equped trucks that I messed with all like 197 for the sync speed. The one stocker liked 189 (I think. It was high 180s none the less).
I found that incrementing the sync speed one numeral at a time rather than 2 or 3 works best for me. Its more time consuming but IMO some trucks dont have a big "sweet spot" in the sync speed they will communicate.
On noisy trucks some ppl were connecting a capacitor between the lap top and the truck to filter out noise and that seemed to help them. Ive been lucky so far and havent ran into a "noisy" truck.
HTH
Sy769
If the syc speed was wrong would it still communicate except at WOT?
Iv'e tried a pretty wide range and it will link but has the errors at WOT
Any more info on where noise filters are needed and exactly what type would be helpful. I know a capacitor when I see one but not much beyond that.
I am in the process of adding more grounds but so far no improvement.
myclone
Id start with a 25v ~1000 microfarad electrolytic cap tied to the chassis and one of the retaining screws on the back of the lap top (use the retaining screws for the com port(s), printer port, etc). I havent actually had to do this myself (yet) but hopefully someone will chime in with some cap values that worked well that might be smaller in value.
Typhoon #1133
Datamaster also stops recording for me about 1/2 the time i try to use it. it is also only at WOT. And i have cleaned all my grounds.
Sy769
Well last nite I added some extra grounds: cab-engine,negative battery post to fender, cab to ecm housing, cleaned all the others I could find.
"Go straight to your garage you are grounded" :lol:
So now what? I am using the belkin usb to serial adapter. It has worked before fine. Seems all my troubles started with the tune-up.
I may pull the Taylors off and see if that changes anything.
I hate electronic, electrically actuated problems. I'd rather have the transmission break a crankshaft than this... :wink:
Sy769
:-? What would a cap do between the laptop and the chassis? Wouldn't a ground wire do the same?
How about a cap between the power supply for the cable?
Or some type of noise filter on the main electrical feed from the alternator?
I dunno maybe someone experienced with a electrically noisy truck will see this and post something. Back to the garage
Later
myclone
The "noise" is actually AC voltage which you dont want in a DC (automotive data circuit). Without going into how R/C filters and ground loops work a cap "absorbs" this unwanted AC voltage (noise) and provides a nice "clean" signal to a sensitive component. The lap top in this case.
Not really as a filter but it would help eliminate the potential for a ground loop (those are bad too).
A cap on the cable to the lap tops power supply wouldnt hurt nor would having a "filter". A cap, along with some other components, is actually what a "noise filter" consists of that are available commercially (Radio Shack comes to mind). These filters are also supposed to help remove the RF "noise" that comes from the ign system and/or altanator. Ever hear a "whine" through the audio system of a car whos pitch seems to vary with engine RPM? Thats the same/similar noise that is prolly affecting your lap top only you can actually hear it through an audio system but you cant here it on your lap top.
Making sure your grounds are clean/good, alt is good, and ign is in good shape all help get rid of "noise". Using a "filter" of some type is a last resort since your treating the symptom not the prob.
HTH
Typhoon #1133
so you are saying the whistle noise i am getting that sounds like it is comming from the days under boost could be comming from the electrical system?
myclone
Keith,
Not to sound like a wise a*@ but Im a little confused on what "the days under boost" means.
Are you getting the whistle through your audio system or is the whistle only happening under boost and coming from outside your truck? If its coming from outside/under the hood then I doubt its the audio system. Outside/boost whistle is a GOOD thing :wink:
Typhoon #1133
Sorry just woke up and i cant think to well this early. Sounds like the sounds is coming from the dash. also sounds like it is near the front left speaker. Only happens under boost so this may be a different problem like a check valve or something.
myclone
Heres how to tell if its coming from noise in the audio system. Turn the radio off and if you have aftermarket stereo (amps, xovers,ect) turn them off too. Go for a drive. Still there? No? You have a electrical noise problem IMO.
If its still there with the audio stuff off then my money is on the check valve being bad that is back next to the dist/FPR. This check valve is tied into the vacuum ball under the battery AND the AC vacuum controls in the dash. FYI.. The check valves are VERY delicate and prone to fail from heat and age. Id locate that check valve, pull the line off the "switched" end (the end of the valve that is tapered), cap off the valve, and then go for a drive to see if the noise disappears.
HTH
Maxtor
Myclone - Since starting this thread, I installed the Ultimate chip and changed the synch speeds all over the place on Sy 959. No change. I also attacked the grounds with no change. I have never had a problem on 1713.
I'll try the cap idea the next time I see the truck. I'm sure the new owner of 959 would like to see a complete Datamaster WOT run at some point. Until then, I've been using Diacom on his truck with no problems. I guess there is one advantage to having both.
