Datamaster data, what to look for...
Inferno
Blew my trans first time out logging... just fixed, put a small stall in it also (figure might as well while out) just went out again, and aside from a little tranny fluid smelling everything seemed ok, but I don't want to just post a file, I want to understand and diagnose myself, is there thread (did search) that lists what to look for... theres alot of info this gives, but unlike my obdII saying hey change this and youll be fine... there is alot more needed to know... any info will help...
Re: Datamaster data, what to look for...
I don't have time to fully explain all the value I am looking for.
Start off at idle. Look at the values do they make sense, the O2 sensor should be switch back and forth under part throttle. Than move on to part thottle. Then move upto part throttle boost, when in boost watch the spark retard. Once in boost the O2 value should be over 900mV. If that looks goods then you can go WOT to check the values.
johnboy89
Just curious was this one for sale in NK recently????
I find the more you log and diagnose the easier it gets...............
