Datamaster file...
ticlone
Esss in the house!
Can someone take a look at a DM file for me and tell me what you think?
The file is a 10-15min ride from school to home. I'm seeing a lot of knock.
Let me know if you can help and I'll email the file.
Thanks!
InvisiBill
Knock is when the air-fuel mixture in the combustion chamber ignites from something other than the spark plug. Hot spots, too much pressure, etc. Higher octane fuel is harder to ignite, so it's less likely to combust from something other than the spark plug. That's why higher octane lets you run higher boost and stuff.
FYI, I graph Spark Retard in red, TPS % in black, RPM in blue, and Boost in pinkish on my DM setup. Gives me a good idea of what the important stats are doing relative to each other.
Anyway, your knock doesn't seem to be related to boost levels or throttle position or anything like that. It seems to be quite random. Knock is detected with basically just a microphone bolted to the engine, and electronic filters that listen for noises that sound like knock. It's possible to pick up other noises that sound like knock, even though they aren't. That's false knock, non-knock being detected by the ECM as knock. Look at rec # 2050 through 2250. Your knock retard is anywhere from 0 to 18.1 (the max I think) even though your boost, TPS, and RPM are all pretty much the same.
To get knock readings that weird, you probably have something else causing knock-like noises. Fuel and transmission lines rubbing or bumping the cab is one place to check. Possibly a bad knock sensor too. Get the highest octane gas you can. This should eliminate any real knock, and show you if all this crap is false knock. Better to spend a few bucks on expensive gas and know for sure, than to assume and blow up the motor because something really is seriously wrong with it...
InvisiBill
No problem. I'm a relative newb still, but I have a good memory. I can repeat stuff so that I sound smart. =)
These trucks are way to stupid for me to say that I'm 100% sure it's false knock, but like I said, it seems totally random and unrelated to what the engine is actually doing.
