Datamaster File
Hu Ryde
I got thae cable for X-Mas anyone want to look at what my truck is doing on the inside? I'm not sure what to look for in the program. This datamaster file was recorded sitting and reving on the engine. No driving. Any help would be great. I think I have a sick truck, to me the knock count is high. I have a chip, msd6-al, exhaust, ic-upgrade, kn, fp, afpr @ 48, timing is advanced 2 degrees, and a new set of NGK ur6's.
http://www.flynnmeteringsystems.com/images/Syclone1178.uni
_________________
Jesse Allmyer
13.32 @ 98.63
Bottles are for babies, real men get blown!
<font size=-1>[ This Message was edited by: Hu Ryde on 2001-12-26 12:37 ]</font>
syntax
here we go :
at idle, your IAC pos is at 0, this is bad it should be at around 40, adjust the trottle stop the get this number up
even at your peak rev your only getting 96% throttle? did yuo have it floored? if so you have a cable/pedal problem, you should get 100%
18.1 degrees of knock retard is ALOT of knock retard
Hu Ryde
Thanks, I need all the help I can get, why does it show my ac clitch being on? Also I did floor it once during the recording. I was not moving though, does this matter on the throttle?
Falco
Jesse,
Some thoughts. I've just seen your -3 file.
First thing. I wouldn't test it with T1-18. Go back to T1-15. You had a spike of 21psi after 2-3, so back it down.
Second thing. Don't push it while it's so cold. Your engine temp was only 135 F when you started. This is the straigth way to blown motor city.
Third thing. Remove the knock. The worst was around 69mph, which could be the TC lockup, but 8,4* is a bit to high for me. According to the O2 readings you are a bit lean. It would be better to see the O2s in the 920-950mV range. Crank up the FP a bit. To 50-52 let's say.
According to the IA temps it's quite cold there. Your run started with 42F and ended with 108F. 108 it's not to high in genereal, but it shouldn't raise like this. Check you IC system. Is it full, pump working etc...
Backing up that 2* of timing would be nice. Get that bolt out. The ur6's are one range colder than the stock so you have already made this step.
I'm also windering why does it shift this high. Are you shift manually? 5100 in 1 is way out from the powerband, but 4775 in 2 is too high as well with the stock motor.
What about you thermostat? Is it stock? 180F? If it's 160 than there could be a problem with the cooling. At the end of the recording you are at 173F.
That's for now, HTH,
Falco
Sy #2613
Hu Ryde
I had been driving the truck for about 20 minutes to warm it up but apparently that wasnt long enough. I did test the truck on T1-18.
I didn't have a tc lockup switch on at the time. So I dont know what could cause knock? Enging tie down strap?
I just adjusted my tv controll. That's why it probably shifts high. It doesn't shift hard either, it like slides into gear. It is set on three clicks ar the tb.
I have a 180 thermostat.
How can you tell what my knock is? How do you read the files? I know the easy ones, MPH, RPM, but what are the weird ones?
Hu Ryde
Falco
Sy #2613
Does 8.4* spark retard mean 8.48* of knock?
What else do tou think I can do for now?
_________________
Jesse Allmyer
13.32 @ 98.63
Sy1178
<font size=-1>[ This Message was edited by: Hu Ryde on 2001-12-27 11:13 ]</font>
Daron
FWIW I just looked at the number 3 file...
Some good points brought up... Looks to me that the boost spike to 21.4 psi correlates to engine loading at the begining of 3rd gear. This is also where the biggest spike of knock is. Notice that O2 volts do not waver at this change in load or onset of knock. While the O2 volts are lower than most, I am not convinced it is a sign of being lean, but more of an indicator of how his particular 02 works.
861 mV seems to be where his settles at the high end, kind of an arbitrary number IMHO. You can see it on and near rec# 514, where he isnt even in boost, and the throttle is at 0%.
The BLM's at part throttle operation have raised a bit off of 128, that may indicate a bit of a lean condition.
What is interesting is if you plug in Turbo WGDC , Spark retard, RPM and boost into the graph you can see why the spike occured. Wastegate is completly shut, big load at the bottom of 3rd, and spiko...
Once it starts cycling the boost response levels out, as the load on the engine levels out too..
So, in my opinion you have a boost control issue as suggested by Falco, and maybe tweaking the fuel pressure is in order to see if it reduces overall knock.
Hope I didnt miss something....
<font size=-1>[ This Message was edited by: Daron on 2001-12-27 12:17 ]</font>
Hu Ryde
What can I do to fix the boost problem? In the manual it shows some sort of gauge you hook onto the wg. What is it and where can I get one? What does it measure? I'm going to raise my fp and get some more runs in tonight. All the help is awesome.
Should'nt the truck run open loop when the tps is at 100%
_________________
Jesse Allmyer
13.32 @ 98.63
Sy1178
<font size=-1>[ This Message was edited by: Hu Ryde on 2001-12-27 18:37 ]</font>
Falco
You are in open loop. DM used to say close loop, but if you check the STerm you can see it's on 128 all the time while you punch it.
The WG. First I'd replace the two vacum lines there if you haven't done it yet. If my mermory serves well the manual talking about some kind of vacum pump with pressure gauage. I'd use a mityvac pump.
Knock. You had three "knocks" on the run (in -3). You spark retard was 8.4*. There is a colleration between the two, but I don't know the exact formula. BTW, the new v3.4.x DM handles the knock count bad. At least for me. There are really high numbers and it's jumping like ~200 for one knock. v3.3.0 was better.
Peace,
Falco
Sy #2613
Hu Ryde
How do I read the {n -3}, where is it? I got some more runs in tonight. I upped the fp to 50 and put in Super 94, I was running 92.
http://www.flynnmeteringsystems.com/images/Syclone1178-5.uni
http://www.flynnmeteringsystems.com/images/Syclone1178-6.uni
http://www.flynnmeteringsystems.com/images/Syclone1178-7.uni
http://www.flynnmeteringsystems.com/images/Syclone1178-8.uni
All are launches again to about 100 or so.
I'm going to replace the vaccume lines soon, I did notice the number 6 file having a boost spike, I ran 3 of them on T1-18 setting on the Ultimate. The last was T1-20. What do you think? Better/Worse with FP. I also installed a Blade of Death tonight before the runs. Like it matters the weather is freezing.
_________________
Jesse Allmyer
13.32 @ 98.63
Sy1178
<font size=-1>[ This Message was edited by: Hu Ryde on 2001-12-27 23:15 ]</font>
<font size=-1>[ This Message was edited by: Hu Ryde on 2001-12-28 01:38 ]</font>
Falco
I meant in you third file. Anyway, don't push. Don't raise the boost, but go back to t1-15 as I said. If you have good results with 15 PSI then you can start to raise. On your last run you had more than 13* of retard.
Pls make a bit longer run than these. Start record a bit earlier and left it a bit after the run. With better gas and with higher FP you got almost the same results. You can still raise your FP, but I'd do the following.
1. Check you IC system as I've already suggested
2. Replace your vacum lines around the WG solenoid
3. Adjust back your timing to 0*, and manually check TDC too
And pls, I beg you, run it with T1-15. Do the above things a let us know.
Falco
Sy #2613
smeagol
Good info here, but I have to strongly stress that you go back to T1 15psi. There aren't many trucks that are setup for regular 92-94 octane to run 18-20psi on.
What are your plug gaps? Is the rest of the ignition in good shape? (I have to ask)
2 degrees advanced timing is NOT a good idea for 93 octane runs on a T1 18psi program.
Hu Ryde
Today I'll try and get some t1-15 runs in. My plugs are ngk-ur6 @.035. I'm going to try and get some highway runs in also. Hopefully I'll get some better results this after noon. Thanks for all the help again.
Daron
Unless Jesse changed something, his truck is actually retarded two degrees. I checked it at the track a while back, per dampner. Didnt piston stop it. Jess, did you go and advance the timing? You were having some knock issues even then, what all have you done to address it since?
Hu Ryde
Sorry guys, I meant to say it was retarded 2 degrees. I guess that changes the whole story. It is retarded 2 degrees, I tried changing it but found the bolt to be froze and I didn't want to strip it out. I have been waiting on a halfway warm day that I'm free to try it again. Once again it is retarded 2 degrees not advanced like I posted earlier. I did get a run today also. It was a T1-15 setting.
Here is the run:
http://www.flynnmeteringsystems.com/images/Syclone1178-10.uni
Complete list of Mods:
http://www.sytyarchives.com/database/viewuser.php?id=145
_________________
Jesse Allmyer
13.32 @ 98.63
Sy1178
<font size=-1>[ This Message was edited by: Hu Ryde on 2001-12-28 16:17 ]</font>
smeagol
What gear was that run in? You spin the motor high (5200rpm) and hold it there, or it won't shift into OD, not sure exactly which. This is when you are getting the most retard, and it could be due to the tranny situation (if it won't shift).
Coolant temps are climbing quickly, this should NOT be happening this time of year if you are in a cold climate. Do a 160 thermostat, and possibly some cooling system maintenance.
TPS is not reaching 100% still. You can check this with the key on/engine off. Hookup datamaster in this situation, and floor the pedal, see what TPS % you reach. You may need to move the floormat, bend the pedal, something. May or may not affect anything.
Your IAT temps aren't bad, but they do climb pretty rapidly, making me wonder what your intercooler configuration is, and if you could improve it.
You may want to check your plugs, double check gaps, see if tightening the gaps helps.
Hu Ryde
The tranny does sometimes act funny like it doesnt want to shift, revs up and then goes like it's slipping. All were launches in [D], I put it in [OD] at around 80mph or so. My coolant system has 2 heat exchangers in-front of the radiator and a external pump along with the stock one to pump it. My intercooler always has a bunch of pressure built up in it, could I have a plugged line, or possibly a froze stock pump? And remember my timing was 2* retarded this whole time, I accidently said advanced, sorry. I really appreciate all your help, I'm starting to understand how all this works.
Hu Ryde
Would a verson 6/7 Ultimate chip make a difference? I remember Ghettosled said it does matter and I told him my mods and he sent me what I have. How can you tell the difference between the two?
I got to looking for answers tonight and found that my pcv's are the originals. The are very oily! They still rattle though. The one on the back going to tb is a ac spark plug brand #799 c. The front one is a ac rockchester #799 c. I went to auto-zone and crossed them over to a Deutsch PCV227. Will this work OK?
I hope to get to the timing tomarrow. I also checkes WOT sitting int he truck with key on. On my computer it said 100% Go figure? Hope to have more tomarrow.
_________________
Jesse Allmyer
13.32 @ 98.63
Sy1178
<font size=-1>[ This Message was edited by: Hu Ryde on 2001-12-29 01:08 ]</font>
Falco
Jess,
BG could ligthen up the ultimate v6 vs v7 question. Anyway in your mod list you mentioned a 10-1 chip. That's something different, you have an Ultimate but not 10-1 (actually 16-1;-) from the chip IDs.
Some words about your IC. With ignition on, engine off put a paper clip between 'A' and 'B' pin of the ALDL terminal (upright corner and next). This should turn on the IC pump (beside other things), so you could check for moving coolant in the upper IC and for the sound of it too. If it's not working it could be several things, blown fuse, bad pump, relay, shortened wires etc). Check first.
Regarding the PCV I'd use GM ACDelco with 'E' on the bottom and nothing else. I've no experience with others.
Falco,
Sy #2613
