Re: datamaster files need help
I just had a code 35 myself. I pulled the IAC valve, tested it and cleaned it. Make sure you soak a piece of cloth in carb cleaner and stuff it in the IAC hole and spin it. Repeat till it comes out clean. Plug the IAC back onto the harness and key on and watch the pintle move. Re install it and pull your ECM fuses to reset the computer. My idle quality improved dramatically and my wideband quit hunting all over the place.
