Datamaster Files
tbauer03
TRBOBOX
New Ignition Module.
http://www.michaelrenz.com/tedbauer-somethingwrong.uni
Jim Sloan's Distributor
http://www.northeastsyty.com/njty180/jims_distributor.uni
Truck shut down when i shut the passenger door and it accidently hit the ecm.
Jim Sloan's ECM and Distributor Same Chip
http://www.northeastsyty.com/njty180/jims_ecm_and_distributor.uni
Now it is not throwing codes but i still think the wiring between the ignition module and ecm is screwed up and hopefully those are the only wires i will need to replace. bc it is indicating EST bypass. My balancer seems to have slipped and i have no idea where TDC is but will find it tommorrow with a piston stop. My question is if it moved once will it keep moving and should i replace it. (stock balancer) I just dropped the distributor in and set it by how the motor wanted to run.
Also any ideas why 02 mv start really low and then climb.
