Datamaster Files
SHADOWWHIT
My second time at Bandimere and first with Datamaster....anyone willing to look at a few runs to tell me how she looks and any particulars so I can start learning myself....
Thanks in advance
93 TY 2185
Re: Datamaster Files
Thanks in advance
Email them to me and I'll post them for you.
SHADOWWHIT
oh, almost forgot....the truck is completely stock with 18000 miles down to the exhaust except for a few small items....its got a hypertech chip and a 160 degree stat....i know...i'm junking the hypercrap before it runs again....it came with the truck and I didn't have timet to fight with it to get the computer out again....also its got a msd coil and a good set of taylor wires and the good cap and rotor everyone talks about....
SBNova
I only looked at file #2. You have approx .950 O2 mv through most of the run, which isnt bad but it is a narrow band sensor are they are known to be inaccurate at WOT tuning. You have 10.5 degrees of KR at what looked like 2nd gear at ~3900 rpm, and some other areas where there is high KR as well. Anything more then about 3 degrees, and you need to make some improvements.
Did you have good gas in it, name brand premium?? At the point where you had 10.5 degrees, I bet you could hear it. If and when you hear that you better get off the gas, or your risking damage. I am not sure on the Hypertech timing routines, like how much is pulled and how fast the retard decays. I would try good gas first (if you doubt whats in your tank) and watch DM while your driving- looking for knock retard. If that doesnt fix it, drop the Hypertech chip and try it again. Let the truck cool off a little between runs so your temps (engine and IAT's) dont get too hot. Again, watch DM for KR and see what happens. If that much retard is still present, get some race gas or some good octane booster, and try it again. If the knock is still there, its either a fuel supply issue (time to upgrade the pump, change the filter and sock) or its false knock (something rattling- triggering the sensor). Even a low mileage truck can have its parts degrade over time.
SHADOWWHIT
thanks!!! I was running on a full tank of 100 octane....up at bandimere......i got the gas from a philips 66 station in town....found it on a motorcycle website from members looking for high octane fuel for there bikes....
