what is the bit map part ?
there alot of red
o2 lean
engine runing flag
est bypass check enable\
ac clutch flag
old cell flag
reference pulse occurred
1= sync map read with 2x ref pulse enable
loop timing fage for timing error logic
extended throttle crack a/c on enable flag
iac kickdown flag
extended throttle cracker
improper shutdown
motor reset complete
closed loop timer
o2 sensor ready flag
not used
power sterring cramp switch
vacume present
fist time c/l flag
rich/ lean flag
does any of this be causing my up and down idle and hic-ups out of the exhaust?
there alot of red
o2 lean
engine runing flag
ac clutch flag
old cell flag
iac kickdown flag
improper shutdown
closed loop timer
not used
vacume present
fist time c/l flag
rich/ lean flag
