In playing with Datamaster, I see the values for Boost Tgt psi and WGDC. IIRC, WGDC is just the PWM percentage applied to the wastegate solenoid. What exactly is Boost Tgt psi? Looking at the data, it appears to be a control target value (possibly in a PI control loop).
I downloaded a couple of other people's DM files they posted, and they did not show anything for Boost Tgt!
On my runs I see a blank for Boost Tgt, and WGDC will start to drop below 100% as soon as MAP goes above ~140kPa; a couple of records later, Boost Tgt shows up, usually down near 7 psi initially, then it settles in close to the expected (near 14.5 psi) boost. Why does the wastegate kick in so early? Does everyone see this happen?
Thanks and regards,
Michael
Thanks and regards,
Michael
