Datamaster Linking Question
TurboManiacal
Hey All,
Pulled out the Datamaster that I had bought (Personal Reasons don't ask) and tried linking my computer to the Syclone.
I quickly found out the cable that came directly from TTS physically links from my laptop to the ALDL port on the truck. There is one serial connector that is un-used...now will it fit/connect between Cable & Laptop.
I physically connected the cable & started Datamaster and the truck started freaking out w/ erratic idle and blinking Check Engine light. There was no PCM sync between Datamaster and the ECM.
I physically disconnected Datamaster and the truck returned to normal.
Later this weekend I went up to NL and tried hooking to Rene's truck with my Laptop. Same results. I then swapped my Official Datamaster Cable with his "home made" cable. Laptop immediately synced up and began recording fine.
Thoughts? Suggestions?
TurboManiacal
GM TURBO said:
Do you have the right cable from TTS?
OBDII cable?
Anyway - I'd say your cable is screwed up :p
Yeah it's the cable from TTS
I'm wondering about this. There's an adapter here...but it doesn't physically fit...maybe I'm supposed to run this?
You know...it's actually kind of depressing to think that I did the right thing by buying the software and purchasing the cable...when I could have made the cable for $40 and cracked the software download.
Freaking disc was a CD copy...with hand written title.
GM TURBO
Sell Out
Well - what kind of adapter is it?
DB9 - DB25?
Take a picture of everything you have and the back of your laptop.
