DATAmaster made me see BAD things
Raist103
Just got my cable from invisibill and got it working this morring and thought the TY was running strong as you can see in my sig. well i did 3 runs 1 from a stop 1 from a roll and 1 from 60 or so. oh my do i have a problem. boost no more then 10 on t1 18 from roll and a stop and 11 max from 60 up. lets not even speak of knock at 4 psi i start getting knock at 9-11 i have 7-12 knock. not good. i dont have my datamaster setup up for 3 map bar but i dont think that will make a differance. but what do i know, will it? and if so how do i change it? or does it detect it automaticly? i can send the 3 files if some one wants to see and maybe i am missing something inportant that is an easy fix. i know i am dreaming but you never know.
phoonrt
I think that diacom only has that cause it reads PSI in Hg. so there is a converion table for it....Btw what number did you finally end up with for the timing??
yes it will make a deferance in what you see as far as boost goes. to change it go to the setup drop down menu and select display units then go down till you find map calibration and select 3 bar then your set
InvisiBill
What Maverick said. The 2-bar and 3-bar MAP sensors use the same voltage range or whatever. It's not that the 3-bar goes up an extra 2V or something. The ECM has no way of knowing which sensor is installed, which is why you MUST use the proper sensor for your chip. DataMaster reads raw data from the ECM, so it also needs to be told whether the MAP sensor's range is supposed to cover 2 or 3 bars.
Glad you got it working, and I hope it helps you get your truck running even better now that you know it does have some problems...
Raist103
ok changed it to 3 bar and i do have proper boost ot ot just off by 1-2 at shifts. so i guess my gauge is bad. but i double checked the files last night and saw that knock went to 13 on one pass but it was also 18psi so i guess i better turn it down to 15 untill i find the problems,
myclone
What octane gas are you using? Reason I ask is that with Shell 93(best for low KR around here) I can only run 17-17.5psi before KR gets out of hand. I cant touch 18psi on pump gas.
Turn the boost down on pump gas is my point unless youre running alchy inj, H2O inj, or xylene mix.
ed hess
race or get outta the way
don go down to atco tonite and buy some 104. worked for me. i use shell 93 for daily driving.
yah so you will have kr on the street but not at the track.
Quick simple fix, just make sure you race at least 1-2 times per week. dont think atco every runs out of 104 :D
ed
Raist103
i use 94. i tried different settings and my aftermarket gauge onl;y reads like 10-15 psi with a spike sometimes to 17 but now i see i m getting good boost my gauge my be bad.
0966Sy
Code what?
What kind of guage? where are you getting the reading from? Might just have a leaky vac line somewhere.
Raist103
autometer -30/+30, from the hard plastic U that comes out of the front of the intake, off of the 90.
0966Sy
Code what?
Yep, make a T in the Brake Booster with the vac line. You will get faster responce out of your guage. Having it in the vac lines has to travel through to much of the lines and reduces the time you would get a accurate reading in and out of vacume and into psi. I changed mine over to the brake booster and noticed alot quicker responce and was maybee a little more solid of a reading. But also I deleted my EGR, Cruise Control, and ABS so that did away with alot of the vac lines.
www.Autoperformanceengineering.com makes a cool fitting
Erik
