Datamaster No Com Selected
tbauer03
TRBOBOX
My old serial laptop no longer works so I tried connecting my new laptop up to data master. I used the serial aldl cable with a serial to usb adapter that I bought from Office Depot. I installed the driver for the usb cable and plugged everything up and turned on the truck. When I go to record in Datamaster it says No Com Selected and under the Comm Port Tab all 12 comm ports are grayed out.
Is this just a simple setting adjustment on my computer or is the usb to serial adapter junk and i need to buy a new cable?
atkonkler
Is this your bush?
Re: Datamaster No Com Selected
You need to find the comport that your computer will let you use to read datamaster..I had to do this with my setup all the time and restart the computer....I'm done with code59. ...it's how old? Just buy a standalone and get into the modern Era of tuning.....:tup:....just my :2cents:.
Quickstop [UK]
Combating adversyty.
The USB to serial adapters are varied in their ability and consistency. The baud rate has an effect and there are some settings you can use. In device manager, your USB connections should appear. Check the properties and see if you can assign the COM port. If it's greater than 12 then it won't show up in DM.
I struggled with the USB to serial adaptor as well and in the end went with a Moates Extreme ALDL. Life got a lot easier after that. Until the next hurdle :D
atkonkler
Is this your bush?
This hasn't come up for a long time. But IIRC, the serial to USB adapters don't work with DM. You may even have issues getting the USB ALDL cable to link. You have to play with data "timing". But go ahead and get a USB cable, and ditch the adapter.
And Atkon: I'd love to have a Holley Dominator. You going to pay the $2,500 it costs for me? Great!. Thanks for the offer. I'll take you up on it.
Davep. If I win the lottery which will be anytime soon ....you might just get your wish! Just like Forrest Gump said....life is like a box of chocolates. ..ya neva know what ya gonna get!:tup:
cloneman315
I have used the Dynex version on mine and on many other things with good luck
tbauer03
TRBOBOX
Restarting the cpu enabled it to recognize the port but it wouldn't sync with the PCM. I am guessing the cable adapter isn't going to work unless you guys know a trick.
