It could be. A solder joint in my cable broke, and I was getting that error. I haven't driven the truck since fixing the cable, so I'm not sure if it was just the cable or not...
The only difference I can see is that this time it was using com port 3, the last time when it worked it was on port 4...I don't know if that makes a difference or not
Using the wrong com port will make all the difference in the world. Make sure whatever com port you select in the program settings is not already being used by another device install in your computer. I had this problem the first time or two I used Datamaster.
________ Laguna Bay II Condominium
