The Washington/Oregon meet was fun, but for some reason my datamaster and truck were both acting up. If Datamaster was connected to any truck, it wouldn't read over 14.6 PSI even though it has in the past and our aftermarket boost gauges all read WELL over that. I don't know why it would do this because like I said, I used to record upwards of 17 psi on my truck before. The boost is definately there, but datamaster doesn't see it on any of the trucks... It was tried on a syclone, my typhoon, and a second typhoon. The syclone and typhoon that weren't mine were running the ultimate and thier trucks were running damned good. I was jealous. I need a good stock tune so I can play with programming or an ultimate!
Another problem: I am running an ATR Pitbull Street and I think it might be part of the knocking problem. I have a massive knocking problem and I need to eliminate every possible cause. I've done a full tuneup and the vacuum lines have been ghetto rigged for the moment, but all controls are working and IAC counts are around 35-40, so they aren't as bad as they were before. Silicone vacuum lines are on the way. I think I am going to need a stock chip or an entire ECM in order to start tuning this thing right. As it sits now, I will not drive my truck without datamaster connected to it so I can back out if *any* spark retard comes up at all. I babied it over the pass and over to the meet this weekend and I wanted to play with everybody else on the freeway but I couldn't %^#@^#$@^$#
I need a stock chip anyway to piggyback the ultimate off of anyway, right? If somebody has a chip they can lend me, or an ECM or if they want to sell it, get in touch with me. I want to try and get this thing unmodified as much as I can so I can eliminate problems one by one.
After the meet, I timed my truck finally and with the timing set to 0, I would get a linear knock increase as I increased the boost. The knock would start around 3-4 psi with timing at 0. Before the timing there would be almost no knock and then it would jump up. The harmonic balancer has not slipped. Just messing around, I kept retarding the timing to get it to run with no knock and I got close, but it was almost 40 degrees retarded when it started to run with no knock. It had little power though.. It would only knock audibly and retard on the 2-3 shift right at the shift point. If I let back off a little bit the spark retard would go away, but then I could ease in to the floor again with no knock. Right now it is about 10 degrees retarded as a happy medium of some sort while I get help figuring out wtf. All the trucks at the meet got 6 degrees spark retard at the MOST. Most were running almost none. Mine is just terrible, but I can't figure out why that would be.
Fuel pressure goes up about 1 psi per pound of boost, btw. I just don't know. Anyway, datamaster isn't working quite right, anybody know why? I'm also looking for a stock chip and/or ECM to buy or use while I fix this thing right.
