datamaster reading
Boostn
91 Syclone on a diet
Please move this to proper category if needed.
Anyways, I drove a 92 Typhoon home which it ran great except for the check engine light that came on after 10-15 min of driving which it was code 32 and the cruise control didn't work. I quickly assumed it was the vacuum hose problem.
So I began to swap out the stock intercooler for the ATR intercooler and did replace few of the vacuum hoses around the check valves and the FPR and to the cruise control module and throttle body. Just whatever broke and needed to be replaced. The Ty now idles kinda rough and runs rough like it doesn't have much power. I thought I did something wrong with the vacuum hoses.
On thing to tell you, I did the cap, rotor, spark plugs, plug wires, tranny filter change, fluid changes on the tranny, engine, axles. But it ran good when I was done, but not now though.
I am not getting any check engine light now after resetting the computer with battery unplugged. Probably because computer doesn't check the EGR not for a while, 10-15 min of driving.
So anyways, I got my datamaster hooked up and let the truck idle and see what is it doing at idle. I haven't drove it yet. If u want me to, I could go up and down the block and provide more readings.
At idle for datamaster, I am giving some readings, I could give u others if u ask for it.
RPM: 725-775 it did spike to 850 few times
MAP KPa: 53.8 it fluctuate 50-56 for a moment
Vacuum KP: 18.5 it fluctuate 16-21
O2 mV: normal fluctuating up and down from like 2 digits to like around 800-900
Spark Advance: 18-21 but it was slowly rising over the time.
Well, I am kinda at lost where should I look into or just keep replace damn vacuum lines. The only thing I might suspect as well is the spark plug wires. They are not brand new, but they are Taylor wires that has been used for about 3-4k miles on my other Typhoon.
Please give me some good ideas and what information u would like to know more. (its completely stock Typhoon with just ATR intercooler)
ed hess
race or get outta the way
to start with 800 to 900 o2 at idle is pig rich. make sure the vac line to the afpr is on and ALL of the vac lines are good.
ed
Boostn
I started trying to test the EGR and follow the vacuum lines from it. I used my vacuum pump. The valve on the EGR works, and the vacuum hose to the EGR from that "black box" on the drivers side valve cover works. But the other inlet on the "black box" does not work, it would not suck anything. I tested the same thing on the other Typhoon, it works as it should when there is vacuum. So is it possible that this "black box" needs to be replaced?
Thanks
ed hess
nope
thats a solenoid valve you are calling a black box. if the ecm isnt telling the solenoid to do anything the air wont flow thru the other port cause the valve remains closed until the solenoid is told to open.
go find out what your fp is and post it here.
post with the vac line off and post what it is is with the vac line on.
ed
Jimmy
Banned
Double check the plugs too.You mave have cracked one on the install,and it's just now showing up.
Jimmy
Banned
The porcelain is very easy to crack on the spark plugs.I'd pull them and make sure there are no hairline cracks.
Boostn
and who knows if u cracked them on removal and reinstall! Yeah, I might as well check that and then if it is all good. I might have to get new set of plug wires. These trucks sure do like to eat them up for snack.
Boostn
aww screw it, I ordered 3 sets of Taylor spark plug wires. LOL, I'll just throw in a new set and then go from there. That might have been the problem anyways.
By the way Jimmy, whats the deal with your avatar? who is that? I hope thats not his little weenie hanging out.
Boostn
Hey, YOU have it as your avatar. Hmm....are u into guys..... I wonder.... J/K.
Not only that, maybe some gay porn......I should stop.......actually one more comment, u know that picture that he took of his gf while in front of the mirror, that is what it reminded me of. LOL
Jimmy
Banned
It's my avatar to make Sigo mad. I bet it works :wink:
MR_MNZTR_SY
running that rich means a missfire. id just go and double check the ign tune. maybe there is a loose plug wire or something simple like that that is noticeable when the intake charge is polluted (like when the egr opens)
