Datamaster Run & Tunning
Zac
Hey Guy's.
I was having trouble getting good datamaster runs when My MSD was located in my glove box. I have since moved it to the engine compartment, and I now have a run that I was hoping someone could help me out with.
I have been using this thread as a base understanding of datamaster:
http://syty.net/phpBB2/viewtopic.php?t=8508
Also, I have been trying to find "trends" with the data. Not quite sure what I should be looking for though. :roll:
Background info about the run:
53*F outside
My timing is about 1.5*retarded (I am going to do a tdc check and adjust timing this weekend, really I will :) )
195* T-stat (I already changed this to a 160*)
Fuel Pressure = 45PSI
Mods:
My struck is basically stock.
AFPR
IC Lines
Walbro
Distilled Water & Water Wetter in IC
MSD Ignition
UR5's
Taylor Wires
New Stock Ign Module
New Stock Ign Coil
Here is what I noticed about the Run:
@ WOT
L Term = 133 (entire run)
S Term = 128 (entire run)
Knock:
1st gear 1-2 *
around 1-2 shift = Around 5.6*
2nd gear 2-3*
around 2-3 shift = Arounf 5.8*
3rd gear knock started around 2ish * and started to rise as I went faster
O2= 880's--> 900's @ WOT
Ia temp started at 110* dropped to 104* then rose to 111* by end of the run
I figured I would Set Timing & Turn Up Fuel Pressure by a pound and make another run.
If you would like to check out my datamaster run and give some advice, let me know, I can e-mail you the file.
Thanks,
Chris
G
Guest
Guest
What kind of gas are you running? 91 octane you have to run fat so you wont detonaite-930's& ^. 101 octane 910's &^.. 116 octane 885's&^
up your fuel pressure a few more lbs. 50 or so my .02 good luck
cheatham
