datamaster vs programmer
chadjett
don't know much about coputer stuff!! what is the difference between these two? which one is better or do you need both??
GM TURBO
Sell Out
Well, Datamaster is a diagnostic program. It tells you what your truck is doing. It looks at EVERYTHING your ECM sees - knock, boost, temp, TPS position - things like dat.
I don't know much about Programer - really don't know Jack about it. What I have gathered is...it is a program that allows you to customize your own chips. Obviously, you are going to have a burner, chips - all that jazz. Honestly, that is about all I know - I could be way off.
jwaller
Evil Genius/SyTy Guru
first off it's not programmer...IT's PROMGRAMMER....Promgrammer is what you use to modifty your existing chip.....then you can use datamaster to see if your new chip is working the way you wanted it to.
flintdawg
so how much is promgrammer....and where can i get it? is it worth it?
_________________
Mike Flint
'92 Typhoon
Red/Red
"Nappin"
<font size=-1>[ This Message was edited by: flintdawg on 2002-01-27 18:25 ]</font>
jwaller
if your into burning your own chips it's $10...awesome deal....its only software though..so you'll have to buy your own chips, burner, eraser and compiler
