DataMaster w/ XP. HELP ME!
sy2206
Ok,
So I got DataMaster for Christmas from my parents and I got it loaded and got my auth code and all the nice stuff. However, I can't get it to link. I'm using the supplied AKM cables ALDL cable, into the AKM converter box. It comes out of the converter box as a 9 pin serial port. From that I have a Serial to USB cable and input the info into a USB port on the back of my laptop. When I start to run the software it all works great, I can play back the sample files and everything is peachy! Now, when I try to link, a little window pops up and says,
"The ALDL adapter is working and data was collected. However, the data collected is not ___?___. This may be an unsuported PCM type."
I don't remember exactly what the second line of the message said. But I know the rest is exactly how it reads. I checked the application and it is for the "4.3 turbo truck" so I know I have the right version of DM. I called TTS power systems and the lady was a bitch and couldn't tell me shit. She didn't know her head from her ass. I hope some of you Sy/Ty computer guru's :D can help me out! Has anyone else ran into this same problem?
Mark Christofferson
P.S. I did try changing the port timing but that had no effect.
InvisiBill
USB adapters can cause headaches. Some have said to disable handshaking, and I've heard people say everything from 0-200 for ALDL timing. On mine (DB9, not USB), I messed around between 190-200 until it worked...
