Datamaster with USB to Serial adapter?
2cold
Wus up folks. I haven't been on the BB for awhile. Like the new format. I'm trying to run datamaster on my laptop using a USB to Serial adapter and a cable made by another board member. I have changed the ALDL timing in increments of 5 from 0 to 500 with no luck. I have also changed it in increments of 1 from 80 to 320 with no luck. The message says that the cable is working but ecm is not communicating and may not be supported by the program. I am using V3.4.17 beta and have also tried using V3.4.1 same results. Anyone with a simillar experience? What do I need to do to get it to work?
sytydvr
disable the handshake feature( forgot where it is but its in one of the menus) hope it works
2cold
I have tried disabling the handshake a couple times, but if I need to try each timing value with both the handshake enabled and disabled it is going to take twice as long and I have spent hours trying to get it to work. Should I contact TTS? I might just have to get an older laptop with a serial port becuase trying to get this to work is too time consuming.
InvisiBill
You may want to try a different USB-DB9 adapter. I haven't had to mess with it, but others have reported that some work great and some don't work at all. Search might turn up something useful...
