datamaster
Nasariobv
ok i finnaly got the datamaster working with the cable i made, now ive read the manual a few times, what should i be lookin for when recording???whta signs??? my rpm does flutter preety bad????
InvisiBill
Knock retard. That means your engine is knocking, and the ECM is cutting back the timing to try to counter it. If you keep doing it, you'll eventually destroy your engine.
Tach flutter is ignition 99.9% of the time.
We can't really tell you what to look for. DM is a diagnosis tool, which just shows what your truck is doing. It lets you collect data from the truck, so you can figure out what it's doing. Just "telling you what to look for" is basically telling you how to understand how an engine works. You have to learn how everything relates to each other, and then use your collected data to figure out how to change things.
I'm not trying to be a jerk, it's just that it's a lot more complicated than "Make value A say 5 and value B say 400, and you'll have a 10 second truck." You're just using DM to collect lots of accurate data, so you can make better decisions. You still have to gain an understanding of what all the data means.
Flyin Ryan
hated cuz he drives fords
I agree with Bill totally also but this may help you figure things out.
02 millivolt
at startup - should be rich/slightly rich (02 is not warmed up, but warms up quickly, and engine needs to be rich at start/warmup) . at idle/cruise once warmed up, you will see 02 values flicker all over, crosscounting across 450mv. at WOT/full boost, you should see them in the 900-1000 range. I've seen them in the 800s, but for the *most* part, 900s is safe. You need to watch your truck and apply other tuning skills to find out what works best for your truck
Knock retard
want to see zero, but hardly any trucks see this. A couple degrees during shifts is normal, but ideal is zero, again.
Integrator
128 is neutral (zero), this will change on the fly a lot once the truck is warmed up and in closed loop. I'd say the normal range is 100-140. Datamaster gives you the option of using S terms (short term fueling trim). 128 is zero, 141 is 10% richer, 115 is 10% leaner, for reference. Crosscounts or xcounts is a running counter of the number of times the 02 readings have crossed 450, going lean, or going rich. This number will overflow at 255 and begin again. At closed loop, this value should be moving pretty fast. It is a good indication of how well your closed loop system is working (or not).
BLM - Block Learn Memory
This value is an attempt by the computer to try to adjust for long term fueling adjustments, due to engine wear, or anything that may change the fuel needs of the motor. We have only 2 cells in our trucks, open or closed throttle. So you may see your values change when you open or close your throttle. 128 is neutral, once again. I'd say you have some issues that need looking at if you are outside the window of 115-140.
Timing
you will see 20-30 at idle/cruise, and should see 12-15 at WOT/full boost. Racier chips will push the timing values at WOT to 17-19 possibly.
Wastegate duty cycle
100% is the solenoid is fully closed, 0% is fully open. Think of it this way, at 100%, the ECM is desiring more boost, at 0% the ECM is desiring less boost.
AFR target
is NOT an air fuel reading. It is a programmed value in the ECM for a fueling multiplier. So at start/warmup, you will see richer AFRs until it is warmed up, when you will see it go to 14.7. Once you go into Power Enrichment mode (you floor it), the AFR will go richer, to 11-12:1 ratios, depending on chip programming, and based off of RPM.
IA temp /MAT
20-40 degrees above ambient are typical. You can watch this value increase with heat soak, or if an intercooler pump is dead. EGR will raise air temps as well, usually 40-60 degrees above ambient.
EGR stuff
EGR duty cycle will kick in during light cruise conditions, unless it is disabled in the chip, or not enabled due to other conditions.
IAC
10-30 at idle is about normal. Adjusting the throttle stop can manipulate this value, as you are creating a slight vacuum leak.
Battery voltage
13s are good, at WOT is very important, 13.4+ being very good at WOT. This will have huge effects on performance.
I believe these to be the most important ones.
Watch when trouble spots are occurring, during WOT, during shifts (graph RPM vs MPH), at boost spikes, at knock, at lean spots (02s dip horrendously). Finding correlations is a start for identifying problems, but be sure it is a cause and not a symptom. (I have low 02s because I have lots of knock...) Watch the changes you can make on a datalogger with actual changes to the truck. Make performance logs to document what helped or hurt. Take notes so you learn from your experience and can share, or at least know your truck better.
