DataQ data logger. Anyone use it?
myclone
I ran across this http://www.dataq.com/194.htm in my research into chip burning/DIY WB.
Anyone ever mess with this? If so what kinda pros/cons are there? Easy to use for a puter moron like me? Anything else out there that would work better and about the same price (little more expensive is ok)? Im just looking for something thats fairly cheap and will record some WB O2 info.
TIA
smeagol
Why not just add the wideband 02 code to your rogram (my keyboard is F'd u and I can't tye one letter, guess what letter it is).
This way, all you have to do is add a single wire to the stock ECM, from your wideband 02, and it will readout on Datamaster/Diacom.
Do the conversion, and you have true wideband 02 AFR readout.
myclone
Thanks for the info.. Ughh. Didnt know that was poss and my only excuse is Im a noob at this :oops: :oops:
canadian
sy in progress
brian;
can you give a rundown of what is required to add the wb 02 to a stock truck? what sort of 02 sensor do you use? is it the honda 02? if so, do you need to add another 02 sensor to the dp, or can you replace the stocker and simply run a new wire to the ecm?
smeagol
Lemme get back to this post later .. busy now, and this weekend... and my surfing at work is gonna be cut back severely next week (hopefully not for long :-? )
CLONE
canadian said:
brian;
Most guys use the techedge or diy-efi board's and the honda o2 sensor. Code hack uses the F14 input (I think) to input the voltage then display it on diacom/datamaster. I'd just replace the stocker (as none of my chip programs use it anyways) and run the WB02 all the time.
That should give you a general idea until that fuck ass brian green stops sitting on his hands and gives you more info.
