Dead!!!!
cheatham2492
Well The plot thickens. I have been working on my ty for 6 or 7 years now and it has finaly stumped me.Lost a turbo,started smoking I had been buying parts waiting to put them on. well the time finaly came to use them. I put on a stealth 70 and A2A a PLX wide band. When I had finished I couldnt get any boost.So I put on a manual boost controller,still no boost. Ran like crap. Got the wide band up and running still no boost. So I put it in first with the break on and stomped on it no boost had the hood open and had my buddy looking for leaks 2200 RPM No boost then....... bam died no juice. keeps tripping the circut breaker. I relocated the battery and thats is ok stil powers fine. but still trips the breaker were the old stock battery wiring is hooked up no starting no lights.Disconnected the old battery wiring from the breaker and the breaker works fine again. I need to find out if there is a fuseable link on the battery cable ? Is there a fuse able link on the alternator?and or a main power fuse for ther breaker box in the cab? Were to start?This ever happen to anybody?
Thanks Dan
cheatham2492
Re: Dead!!!!
Chased the wired diagram down. I Found my circut light and tested every thing. The hot "battery" lead and the alternator lead made a complete circut. so I know that the fusable links are ok and the wire is grounded out or shorted out some where to make the circut. The wire diagram says that they go directly into the ignion switch. So I will have to test there and if not that keep tracing to the ECM . the fuses on the fuse block are OK but it could be the ECM it is next in the diagram. Till tomarrow
Dan
