degreeing cam w/ comp cam 412
ed hess
race or get outta the way
Comp cams instructions say you dont actually have to degree your cam.
They also say they have 4 degree advance built into the grind.
Using this cam do you just line up the mark on both cam and crank gear which leaves the cam with the 4 degree of advance?
or do you degree the cam back to take out the 4 degree advance?
Since i have the wheel and gauge, and fixture i will double check it anyway.
but how did you all set it?
Leave it with marks as is or take the advance out?
Many have used this cam here so this should be an easy question.
ed
jwaller
Evil Genius/SyTy Guru
yes I have and esp when I did the belt drive setup onn my ty motor. they have always checked out really close...+ - 1 deg...
ed hess
So if your off one degree does comp cams sell an adjustable cam gear for our motor? (had one of these years ago i put on my volvo gt. Yeah a volvo with cam and headers...... :D)
I dont think 1 tooth on the cam sprocket could fix that.
ed
ed hess
ok straight up it is. Shaken not stirred :D
I will checkit anyway since i have the fixture, wheel and gauge.
confirm they actually build 4 degrees advance into it.
I just wanted to be sure i fully understood the recipe here, especially since no one had ever mentioned it or asked.
ed
smeagol
When I did my cam install (the 422 model) I checked it, degreed it and checked *their* data. When I installed it straight up, it was 7-8 degrees advanced. I checked almost every other cylinder, just to check the accuracy of the cam grind, and several were spot on, couple were off 1-2 degrees.
I called Comp Cams tech line, to ask about the degrees advance built in, and why I had more than 4 (this was checked, doublechecked, triple checked, and by other people). The tech was frickin' useless, just reading off of a basic help sheet. He kept giving me instructions about using a piston stop, when I told him 13 times "THE HEADS ARE NOT ON THE ENGINE"...'ok sir, i understand... so after you put the piston stop, you rotate the motor one way.... me: <huge sigh by me into the phone> " are you done yet ? ". That ranks up there with one of my most annoying phone conversations ever... where was I... camshaft, yes.
So, since I realized they had ground extra advance into the cam, I used the keyway on the timing chain sprocket to put the advance back to like 3 or 4, based on my measurements (I believe there are +4 and -4 deg in the keyways).
Lessons learned - always degree your cams - assess a phone tech's skill level before following any advice
Sy#26
Similar situation speaking w/ tech support @ Iskenderian (I use Isky 252/257); tech told me cams were ground slightly advanced to compensate for eventual chain stretch. This tech knew that piston stops came in two flavors, though, 'heads on' & 'heads off' types. I, also, measured a total advance "out of the box" of 7°, so used an offset bushing to retard it 4°, bringing it to a total advance of 3°. Just make sure you understand which way the bushing goes in the sprocket - I screwed up first time & advanced it an additional 4°.....duh!...:roll: Got pretty good at R&R'ing the cam - BTW, you *can* remove the cam w/o opening the A/C system - condensor will swing far enough to allow removal.
