Deleting knock sensor
mattw
Re: Deleting knock sensor
Nope.. The stock ECM does a diagnostic test every time you start the engine and 1st start driving. It purposefully advances timing and verifies that it sees knock. If this test fails the SES light comes on. I can't recall if this puts you in limp home mode or not. To delete it you would need a custom chip.
Have you tried to relocate it? I made an adapter and mounted mine on the upper intake back when I was getting false knock on my old Ty. I'm sure that desensitised it some but it still passed the diagnostic test and seemed to function as it should...
cjg454ss
Yea I've moved it to the front of the intake but my alternator is making some noise at the upper rpm.
If your alternator is making that frequency of noise, you need to fix it.
You can disable the knock retard in the chip.
ajt86
Disabling knock retard in a turbo truck is going to cost you an engine. Fix the false knock
Couger1968
Dazed and Confused
I don't think you can diagnose knock with plugs unless it's really really bad .I think you would be better off finding out what is causing false knock. Like was said could cost you an engine. I would make sure it's the right sensor and torque it correct to start.
I think if the knock sensor is disconnected it takes out 4 degrees of timing.
cjg454ss
That's not true at all. I prefer to not knock at all and add timing according to what the plug reads.
Aeroking
e.i.
by the time the knock sensor sees it and the ECM reacts, you have rods out the block. If it's tuned right it shouldn't detonate.
Quickstop [UK]
Combating adversyty.
Knock/detonation and preignition are two different things from what I have read. Knock, or "pinking" in the UK :D, is just a little bit of detonation. It will wear the bearings and piston down over time. Preignition is the thing that will kill the motor in a hurry and no ECM is going to prevent that if you have a bad setup.
http://www.contactmagazine.com/Issue54/EngineBasics.html
