deleting stock air intake ?
psmvchaser
To make a long story short, I am relocating my battery, and putting a K&N cone filter in the batteries old place.
My question is, what do I do with the two recirculation hoses that come from the pcv valves/driver side vent?
On the stock intake they are recirculated, but I am not sure what to do with them now. I know this mod is fairly common, so I was wondering what everyone else has done.
Any suggestions/knowledge would be greatly appreciated.
Ken
Re: deleting stock air intake ?
The driverside can use a valve breather. I would recommend for the PCV valve that you tap into new air filter set up. The port on the crossover tube will unscrew. The subject has been covered, try a search.
kwick6
Hey Ken,
You can delete the drivers side PCV and just put a K&N filter in place. Then you just need to run the line that went to the stock crossover tube into the intake hose for the turbo.
I have a piece of 3" stainless you can have that can go between a cobra head intake and K&N filter, then you just need to drill a hole and mount a hose barb fitting for that line.
later,
SY2932
Administrator
kwick6 said:
Hey Ken,
later,
SY2932
Administrator
Uh it's the stock one that is attached to the black plastic cross over tube...
TYTILIDIE
METH HEAD
I ditched everythting and ptu breathers in place. I do plan on hooking up the PCV on the pass side eventually. But I havent had any problems without yet.
Mike
Flyin Ryan
hated cuz he drives fords
I'd like trying this setup
syty%20shizle
syty%20shizle
*edit I can't figure this "posting image" crap out*
Captain Morgan
Moderated User
I just cut that damn hose off that went to the crossover. my truck always ran better without it hooked up in the first place, been like that for 2 years or so now, no problems.
