DesertSy #2144 make offer
Status
Not open for further replies.
DaveP
Finalized the deal tonight. It sold for more than my asking price which was $8,750. It's headed to the East Coast. I learned some stuff about how NOT to sell a car. Life is a learning experience. I never make the same mistake twice. I make new ones every day.
Thanks for the interest.
Pics from my files:
January 15, 2016:
I'm bumping this. I'm ready to see it go. I've had fun with DesertSy, and I'm glad I did the project, but it's time. I have #1230 to finish, and I have the Ty for my run around car. It can be driven anywhere in the Country with confidence it will make it. Fly into LAX, I'll pick you up and drive it home. Or I frequently travel, and may be able to deliver for cheap. Talk to me.
I completed it in October 2012. I've driven it about 16,000 miles since, 12,000 of that on highway trips of 1,000 miles or more each. It went to Bowling Green for Nats 13. I drive it for errands pretty much every day, and drive it pretty hard. It doesn't break, knock, or leak. It's pretty reliable for a Syclone. It will be as good a driver for someone else as it has been for me if it isn't beat mercilessly or chipped without knowing what yer doing.
The build thread is here. I'll try to add some recent pics over the next few days.
DesertSy is my 4th extensive SyTy Project I've undertaken for my own use and amusement. This was not built by a SyTy-Illiterate. I know what I'm doing. I pretty much took this entire truck apart, cleaned it, and repaired or replaced almost every item in it because it needed it. It's now complete with every factory fastener, bolt and bracket in its proper place. Every cut wire has been repaired. Every bit of jankiness that existed when I purchased it has been eliminated. It drives very tight. Nothing leaks or seeps. The brakes are phenomenal. Even the ABS, cruise, and A/C (R-12) function as-new. The only thing that doesn't work are the lumbar pumps in the seats.
Because there are none of its "born-with" original mileage-sensitive components left on it, to me, what the odometer indicates is irrelevant. It says 92,xxx BUT I ROLLED IT BACK 100K WHEN I BUILT IT. The carfax probably caught it, because Kalifornia still reports odometers when emissions tested. So it's been driven almost 200,000 miles. Never wrecked, no bondo or replacement metal anywhere. Rear corners are fiberglass. I have its Window Sticker. I believe I'm the 3rd owner, The previous adult owner had it 15 years, I've had it 5.
It's very clean, paint is glossy, a few blemishes (mostly door dings in the cladding) and not a spec of rust anywhere. Not on the sheet-metal, frame, suspension, anywhere. I mean it. No rust. The body paint is not black. It's a very deep charcoal metallic. It has very small red and green fleck. It looks black, most of the time. The cladding is cranberry, possibly the Impala SS color. Cladding is complete, and not cracked.
Overhauled as part of the build:
Engine: Stock pistons, crank turned 10-10, very mild cam, but it made a difference.
Transmission: Not an original LHM, but we modded it to be very similar. It works very well.
T-Case: V-clutch, bearings and chain.
Front diff
Front axles
Everything under the hood
Everything in or behind the Instrument Panel
Replaced with new:
A/C compressor
Alternator
Power window motors, window run channels, and belt-line fuzzies.
Idler and Pittman arm.
Water pump
Tune-up parts
Cat converter
O2 Sensor
Heater Core
Battery
Tires
Headliner
Recent Windshield
Replaced with good used components (because the ones that were on it were bad, broken, leaking, or missing): (Read the build thread. this list isn't complete).
Power steering box
Power steering pump
Brake booster
A/C evaporator and suitcase; blower motor.
Wiper motor, washer pump,
Radiator, fan and clutch, shroud.
A/C condenser.
Upper Intercooler, IC pump (stock bosch)
Turbo and Wastegate
Air Cleaner and crossover tube
All coolant lines, hoses, and fittings.
Goodies:
Baer Brakes front and rear. E-Brake complete and functional
11.5 R, 9.5 F A-Mold wheels. Sumitomo 315/275 tires.
1-1/2" rear blocks, front 1/2" lower.
ATR 3" SS cat-back Exhaust.
Astro Van steering shaft mod.
Front "Gilbert" prop shaft. (I don't know if it's a genuine Gilbert, but it's like his components).
Typhoon OSRV Mirrors. Functional
Typhoon RKE. Functional
(2) 12V outlets in center consol (Typhoon)
Delayed Accessory Buss. Stereo and windows stay powered up until driver door opened.
Pillar mounted single-pod boost gauge.
Anyway. It's a well-sorted, functional, tight-driving, rust-free Syclone with a fully reconditioned drive train, refurbished interior, and presentable exterior. It's fully California smog-legal, too. Tags paid through Feb 26, 2016.
Let me know if interested. Thanks for reading.
sytyguy
Moderated User
Re: DesertSy #2144 make offer
Dave, we have some potential buyers in my area. I'll put the word out. Regardless, GLWS.
DaveP
Re: DesertSy #2144
Re: DesertSy #2144
I'm serious. Original Post updated. .
A 190,000 mile, 100% rust-free, leak-free Syclone that needs nothing to be enjoyed daily.
jaystcb
Sy 0902, 92Ty 0909
DaveP, need to edit your post. ( brakes F & R are swapped).
I will also vouch for DaveP and this truck. Dave let me borrow DesertSy for a couple days when we rebuilt the trans in my Ty. I did not want to give it back. It is a very solid driving truck.
Here is a pic from one of the Ruby's Diner Meets.
DaveP
Re: DesertSy #2144 $8,750
Thanks for the pic. This truck still looks like it does in these pics when its cleaned up.
Those sizes are for the wheels, not the brakes. But you bring up an interesting point. This truck has 13" rotors on both the front and the rear. Usually the rear rotors are 12". At least the conversions I've seen are. This truck has big big-brakes. It stops really well. You've driven it, so you know.
jaystcb
Sy 0902, 92Ty 0909
Opps. sorry. I don't know how I misread that.
Good luck finding her a home.
P.S. I added your post to the for sale section on SyTy Facebook.
jaystcb
Sy 0902, 92Ty 0909
I payed $13K for my Sy with 140k and it is not even close to being as good as a driver as DesertSy. M2C is... In today's market. If DesertSy sold for 13K, you would be getting a hell of a deal. It is worth every penny if not more. It is basically a new truck.
Z SKI
As all have said, this is a great running and operating Syclone.. I have driven it many of times and she doesn't disappoint.. Before I got my Ty and since my Sy has been down for ages, Desert Sy used to be my go to for a SyTy fix.. The little cam woke it up nicely and she has some serious brakes!!
Good luck with the sale Dave.... Oh.... And just to reiterate, this is the epitome of a rust free truck!!
Damian
Id buy this Sy in heart beat if the wife wouldnt kill me in my sleep for doing so.
Jimmy
Banned
Desert Sy is the only truck that you can factaully say has no rust.
Next Phase
Dave,
It was great speaking with you today.
Sent you my information via text.
-Marko
Status
