Deshrouding needed for larger valves?
B
Blake
Guest
I have a set of L-35 heads that I will begin working on after I get my transmission finished. I was tossing around the idea of installing 2.02 intake and 1.60 exhaust valves but was concerned about combustion chamber shrouding. It would make sense that if a larger valve was installed, it would obviously get closer to the edge of the combustion chamber. Is it an issue with our heads? I'd hate to go through all the extra expense just to hamper all the port matching and polishing(on the exhaust side only of course) I'm doing.
If anyone has deshrouded the valves, how much material could be removed and still have a durable head?
Thanks!
smeagol
Good question - are the larger valves worth it?
To me, I'd say to spend the money on cleaning up the chamber (smoothing it out big time) and working up the intake & exhaust port for mid range flow. If I was on a huge budget, I wouldn't do the larger valves, If money wasn't such a huge concern, I'd do valves. It all really depends on your combination and goals. If you just want a bit more performance, I don't think the larger valves are going to help tons. If you are going all out, and have a bigger cam and whatnot, any extra CFM will probably help.
I was told by one head guy that the larger valves aren't really needed due to bore and whatnot.
Hope that rambling helps...
Buster
Don't you have to replace the stock L-35 valves anyways? I thought someone said our stock heads have some type of harden valves.
B
Blake
Guest
Thanks guys. I recently read that if I were to go to larger valves the benefits wouldn't be seen until I got into very high lift. Higher than the .460 I plan on using anyway. Thanks for responding. I'm pretty sure I'll end up using Manley stainless stock sized valves with the straight or necked down stems and do the typical 3 angle valve seat job and maybe back cut the valves. If you look at the stock stems, they have this huge lump of material right before you get to the valve face. I'm sure it adds strength and heat absorbing ability but I'd imagine it is needed because of less than top of the line material they used when the valves were mass produced.
>Don't you have to replace the stock L-35 valves anyways? I thought someone said our stock heads have some type of harden valves.<
You might be talking hardened exhaust valve seats. Any engine that is designed to use unleaded fuel will have them. As far as hardened valves, I doubt it. GM never was into spending any more than they had to in order to make a profit. The engine is the same except for the hyperutectic pistons(lower compression ratio), main bearing caps(nodular iron), better bearings(clevite 77 I believe), and exhaust manifolds as well as everything else on the outside.
Buster
Yeah I wasn't really sure, just thought I'd ask because I'm doing my motor as we speak.
Thanks
Mark Larson
